China UV Bandpass Filter suppliers
fish4fi
Mensajepor fish4fi » 25 Jun 2019, 09:26
365nm, mercury exposure lamp UV bandpass filter
BP365nm mercury exposure lamp UV bandpass filter is mainly used to pass through the 365nm high-pressure mercury lamp spectrum to cut off other spectra, thereby improving the signal-to-noise ratio of integrated circuit exposure lamps and forensic instruments.
1. the product introduction
Kingki Optical's high-performance UV narrow-band filter is produced by using dielectric hard film by vacuum ion-assisted coating, which makes the film dense, drift-free, wiping resistant and not easily eroded by moisture. An anti-reflection coating is applied to increase the transmittance and increase the energy of the light.
UV filter with a wavelength of 365 nm
2. 365nm UV filter curve: (You can fill out the demand form at the end of the article to tell us that you want the product)
3. the application:
The BP365 mercury lamp UV bandpass filter is mainly used to pass through 365 wavelengths and cut off other wavelengths, thereby improving the signal-to-noise ratio of integrated circuit exposure lamps and forensic instruments.
4. the company's strength
Kingki has long been responsible for the research and production of military optical coatings. The chief engineer has more than 40 years of military optical coating experience, and has 33 national authorized patents. Nine optical film systems have won the People's Republic of China Science and Technology Progress Award.
Kingki has a high-end factory building of 4,000 square meters, 13 sets of advanced coating machines and complete test equipment, with the ability to mass produce high-end optical filters.
Kingki's wide range of products, excellent performance, high quality and low price, prompt delivery
5.Demand table
band pass filters
AOIcentralFWHTTpekblockODmetalDpurposequantitydelivery
e.g.10°785±2nm10±2≥80%200-11006no10fluorometric2
yours
For the purposes of most of the coatings that we will discuss here, we will assume glass of index of 1.52, although this varies somewhat with the par- ticular glass and also with wavelength. Although much of what follows is applied directly to the antireflection coating of crown glass, the techniques apply equally well to the coating of other low-index materials. We begin with the simplest coating, a single layer.China UV Bandpass Filter suppliers
website:http://www.kkopticalfilter.com/uv-bandpass-filter/
